Whether you want to escape pressure, beat a defender one-on-one, or create space inside the penalty area, mastering different dribbling techniques can make you a much more dangerous attacker in FC 27. Players who understand when to slow down, accelerate, or protect the ball can create more opportunities and make better decisions in tight situations. This guide explores seven essential techniques, including FIFA 27 Coins as part of the broader Ultimate Team experience, while focusing on the controls and practical skills that help you improve your attacking game.
1. Left-Stick Dribbling: Build Your Foundation
Left-stick dribbling is the most fundamental technique in FC 27. Simply move the left stick in the direction you want your player to go. Although this method is slower than sprinting, it keeps the ball close to your player's feet, making it easier to change direction and react to defenders.
The key is timing. Your player cannot instantly redirect the ball every time you move the stick. Instead of moving it randomly, watch the ball and coordinate your directional changes with each touch.
You should also observe your opponent's movement. When approaching a defender, move slightly in one direction to encourage them to commit before quickly changing direction with the next touch. This can open space for acceleration. Left-stick dribbling is also valuable for maintaining possession in midfield when you need to escape pressure and find a safe passing option.
2. Sprinting and Knock-Ons: Exploit Open Space
Normal sprinting uses R2 or RT and helps you cover large distances quickly. However, sprinting usually creates more space between touches, reducing ball control and making sharp turns difficult. Use it primarily when there is open grass ahead rather than when approaching a defender directly.
Knock-ons allow you to push the ball farther forward using the right stick while sprinting. This helps your player cover more ground between touches and is especially effective during counterattacks.
You can also hold the right stick in the direction of your run to push the ball farther, or quickly move it twice in a direction for a sudden burst. These actions can be particularly useful when receiving a pass while already moving forward. Remember that each knock-on is applied to a specific touch, so time consecutive actions around your player's contact with the ball.
3. Analog Sprinting: Control Your Pace
When analog sprinting is enabled in the settings, your running speed depends on how firmly you press R2 or RT. A lighter press produces a slower run, while a stronger press increases your speed.
This mechanic offers additional control over your pace, although its effectiveness may vary compared with previous editions. Use it to adjust your movement to the available space rather than sprinting at maximum speed in every situation. Controlling your pace can help you approach defenders more carefully and avoid pushing the ball too far away.
4. Controlled Sprint: Combine Speed and Control
Controlled sprinting, activated by holding R1 or RB, is particularly effective in FC 27. Your player moves faster than during normal left-stick dribbling but generally takes more frequent touches than during a full sprint. This balance gives you a useful combination of speed and control.
Approach a defender with controlled sprinting to maintain forward momentum while keeping the ball close enough to change direction. When the defender commits to one side, adjust your direction and accelerate into the space they leave open.
This technique is also useful immediately after receiving the ball or when starting from a stationary position. Briefly releasing R1 or RB and pressing it again can help you create another acceleration opportunity in tight spaces. Players with strong dribbling attributes and suitable technical PlayStyles may benefit even more from this approach.
5. Strafe Dribbling: Keep Your Body Facing Forward
Strafe dribbling uses L1 or LB while moving the left stick. Rather than constantly turning toward the direction of movement, your player can remain oriented forward while making small sideways or backward adjustments.
This is useful when facing a defender near the penalty area. Move laterally while keeping your body facing the goal, forcing the defender to decide whether to follow you or protect the space ahead. Once they react, release L1 or LB and accelerate into the opening.
You can also use this movement to set up a straight-line burst. Hold L1 or LB and move toward your intended direction, then release the button and immediately press R2 or RT while maintaining that direction with the left stick. The transition from controlled movement to sprinting can catch an opponent off guard.
6. Slow Dribbling and Shielding: Protect Possession
Slow dribbling uses L2 and R1, or LT and RB, to make small, controlled adjustments. It is particularly helpful in crowded areas when you have little room to turn. For example, when receiving the ball inside the box with your back to goal, use one or two touches to adjust your position before shooting, passing, or switching to another dribbling technique.
Avoid holding this movement for too long because your slow pace gives defenders time to recover.
Shielding, activated by holding L2 or LT, uses your player's body to protect the ball from nearby opponents. It is valuable when a defender approaches from behind or from the side. Shield the ball while assessing your options, then turn away, pass, or accelerate when an opportunity appears.
7. Effort Dribble Touch and Controlled First Touch
The effort dribble touch lets you push the ball deliberately in a chosen direction. Hold R1 or RB and move the right stick toward the space you want to attack. Unlike ordinary left-stick dribbling, this technique focuses on directing the ball into a specific area.
Use it when facing a defender and you can clearly identify an open side. Watch the opponent's positioning, choose the available space, and push the ball beyond their reach.
The controlled first touch applies a similar idea before you receive a pass. Hold R1 or RB and move the right stick in your intended direction as the ball approaches. This helps direct your first touch toward open space instead of allowing the defender to dictate your next move. It can be especially effective when receiving the ball with an opponent close behind you.
Final Thoughts
Becoming a better dribbler in FC 27 is not about using the fastest technique every time. It is about recognizing the situation and choosing the right response. Use left-stick dribbling to read defenders, sprint and knock-ons to exploit open space, controlled sprinting to combine speed with control, and shielding to protect possession. Practice strafe dribbling, slow adjustments, and directional touches until they become natural parts of your attacking game. With consistent practice, you'll create more chances, beat defenders more confidently, and build a stronger Ultimate Team without relying on a single move. Whether you are improving your gameplay or developing your squad with FIFA Coins for sale, learning these seven techniques can help you make smarter decisions on the pitch.
How to Dribble Like a Pro in FC 27 – U4GM Tips
Sjolund
