RSVSR What to Do to Catch a Lightning Strike in ARC Raiders
Hartmann846
Сообщение Hartmann846 »
I never thought I'd be the kind of player who runs toward an Electromagnetic Storm, but here we are. When you're chasing weekly tasks, or you're trying to bankroll your crafting habit without burning through ARC Raiders Coins, taking a lightning hit on purpose starts to make a weird sort of sense. It's not "free loot" and it's not consistent, but once you learn how the storm picks targets, you can make it happen often enough to matter.
Reading the strike before it lands
The game does give you a tell, and it's easy to miss when you're already stressed. Watch the ground. Right before a bolt comes down you'll see light crackles, tiny sparks, or a faint ripple in a small patch like the air's buzzing. That patch is the danger zone and also your invitation. Most people instinctively dodge out of it. Don't. If you're trying to get tagged, step into the middle and commit. The timing's tight, too. If you shuffle at the last second, even a little, you'll end up "almost" struck and that doesn't count for anything.
Where to stand and what not to do
You'll also want to stop playing like you're avoiding a sniper. Indoors, under a thick overhang, tucked into dense cover—none of that helps. Pick an exposed spot: a field, a roof with no protection, a long stretch of road, even an open platform. Then stay in motion. From what I've seen, the storm feels more interested when you're moving through open space rather than crouched and holding an angle. I'll do small loops, quick sprints, change direction, then swing back into the crackling patch when it appears. If enemies are nearby, fighting can keep you out in the open long enough to get a strike opportunity, but don't overcommit. You're not farming kills, you're farming weather.
Taking the hit without throwing the run
A direct strike hurts, but it's not always a death sentence. Go in topped off, with shields that aren't already shredded, and plan your recovery before you get hit. The moment the bolt lands, you'll usually be limping and exposed. So preload your hotbar with heals, pick a fallback route, and clear your immediate surroundings first. Getting zapped is one thing; getting finished by a random bot or a third party while you're panicking in your inventory is the real way runs end.
Why it's worth it right now
The payoff is the drop the strike can leave behind—Fossilized Lightning—and it's one of those materials that makes crafting and trading feel a lot less grindy. The catch is that storms aren't as relentless as they used to be, so you may get fewer clean chances per raid and you've got to be patient. If you're trying to keep your loadouts consistent between attempts, it also helps to use a reliable shop for gear and currency; that's where RSVSR fits in, since it's built around getting game items and currency without turning preparation into another grind.
