U4GM Guide: How to Use the Venator in Arc Raiders
Добавлено: 19 сен 2026 10:43
glico
Under sustained pressure, the Venator exposes every mistake in your Arc Raiders loadout: miss two shots during a close-range push and its low magazine, limited follow-up damage, and heavier handling can turn a clean finish into a scramble. That is why I treat it as a precision sidearm rather than a miniature primary. Players checking ARC Raiders BluePrints should first decide whether their available weapons support this role, because the pistol performs best when another gun creates the opening. Its value appears in short fights, not in prolonged trades across open ground.
Use the Venator After the Fight Has Started
The most reliable sequence is simple: open with a primary weapon, force the opponent behind cover, then draw the Venator when the distance collapses or the enemy is already weakened. This creates a compact burst window in which accurate shots matter more than sustained DPS. The pistol is also useful when a reload would create too much animation lock. A fast weapon swap can preserve uptime while the opponent is crossing a doorway, climbing over cover, or recovering from crowd control. The key is to enter the exchange with a clear purpose. Do not draw it just because the target is nearby; draw it when its handling gives you a timing advantage.
Why Movement Beats Raw Fire Rate
A previous adjustment reduced the fire-rate gain from upgrades and increased the weapon's weight, making constant trigger pressure less forgiving. That change shifts the Venator toward deliberate movement and tighter shot selection. Fire from one angle, break line of sight, and reappear from a different piece of cover before the opponent can settle their aim. If your crosshair placement is inconsistent, extra fire rate will not solve the problem. A useful practical target is effective uptime: spend less time exposed between shots, and more time forcing the enemy to search for you. This approach also protects your health pool during multi-party encounters.
The pistol's stat breakpoint is most noticeable against lightly armored Raiders and smaller ARC threats that can be finished with a short string of accurate hits. It is far less comfortable against durable targets, shielded opponents, or enemies who can maintain pressure while you reload. Queens and Matriarchs should not be treated as Venator assignments. Bring a heavier primary for those major machines, then keep the pistol ready for nearby Raiders, exposed weak targets, and emergency defense. Damage mitigation matters here: a weapon that saves one reload is useful, but not if using it leaves you standing in a hazard zone.
Build Around the Moments That Need Speed
The strongest Venator loadout separates responsibilities. Choose a primary with dependable reach and enough magazine capacity for the opening engagement; let the sidearm handle the final meters, interrupted reloads, and sudden room fights. Carry ammunition with restraint, since the pistol loses much of its value when every encounter becomes a full magazine commitment. It fits players who enjoy controlled shots, quick repositioning, and reading enemy movement. It is a poor choice for anyone who wants to hold one angle and win through continuous fire. If your progression leaves a gap in your kit, you can buy ARC Raiders Items to fill that role, but the Venator still rewards practice more than extra gear. Treat it as a timing weapon, and it becomes a dependable finisher instead of an emergency button.
