With the clock closing in on September 20, Farmers Market Partners becomes a pressure test rather than a casual token-spending event. Three attractions can look healthy while one underdeveloped board quietly threatens the entire reward track, especially when your remaining spins produce weak token income. I have seen this happen after players spent early resources evenly, only to discover that the final attraction needed a large push at the worst possible time. Checking your Monopoly Go Stickers collection may help with other progression goals, but the immediate priority is reading all four Partner boards and locating the weakest attraction before every decision becomes expensive.
Read the Board Like an Endgame Problem
Total progress is a poor measurement during the final stretch. Open each attraction and compare its current bar, the next major reward, and the amount still required for completion. Then check which partner has contributed the least, because uneven participation can leave one board much farther behind than the combined event total suggests. The most useful metric here is remaining investment, not visual momentum. An attraction sitting near a reward breakpoint may need only a controlled token spend, while another that appears respectable could still demand several large upgrades before reaching its final checkpoint.
Give the Weakest Attraction a Realistic Budget
Once the problem board is identified, estimate what your current Partner Tokens can actually accomplish. Do not assume every future spin will land perfectly or that every activity will provide enough resources to cover the gap. Produce Profits remains one of the key token sources before the event closes, with milestone rewards that can add thousands of Partner Tokens alongside Dice, Sticker Packs, and temporary boosts. Treat the event as a resource pipeline: Dice create points, points unlock milestones, milestones provide Tokens, and Tokens repair the attraction with the highest completion risk.
Spend Around Milestones, Not Emotion
The practical decision is whether the next useful Produce Profits milestone is close enough to justify another rolling session. If a token reward sits just beyond your current score, reaching it may materially change the weakest board. If the milestone is distant, burning Dice for small progress can leave you short of both Dice and Tokens. This is where resource timing matters more than raw volume. Protect a reserve for the final attraction, and avoid spending simply because a progress bar is available. A completed attraction has no further value as a target, while a nearly finished board may deserve a precise final push.
The Last Day Rewards Completion, Not Showmanship
Farmers Market Partners does not reward an impressive single attraction as much as it rewards completing the required set. That changes the correct play pattern as September 20 approaches. Early in the event, spreading Tokens across partners is reasonable because you are still gathering information. Near the deadline, unfinished attractions become the only meaningful threat. Your final sequence should be straightforward: identify the largest remaining gap, calculate the Token income still available, keep a reserve, and spend when a major reward or completion checkpoint is within reach. If you decide to buy Monopoly Go Stickers, keep that separate from your Partner Event budget and finish by pushing the last incomplete attraction before the timer expires.
U4GM Monopoly GO Weakest Attraction Strategy Guide
glico
